Aller au contenu principal
Asus R541UA-RB51 Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: étape 1, image 1 de 3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: étape 1, image 2 de 3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: étape 1, image 3 de 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Hard Drive Replacement: étape 2, image 1 de 2 Asus R541UA-RB51 Hard Drive Replacement: étape 2, image 2 de 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Hard Drive Replacement: étape 3, image 1 de 2 Asus R541UA-RB51 Hard Drive Replacement: étape 3, image 2 de 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
Steven Tate
Membre depuis le 08/31/18
191 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 688
