Introduction
This guide is for the replacement or upgrade of the hard drive.
Ce dont vous avez besoin
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
