Aller au contenu principal
Asus R541UA-RB51 RAM Replacement
Ce dont vous avez besoin
  1. Asus R541UA-RB51 RAM Replacement, Keyboard: étape 1, image 1 de 3 Asus R541UA-RB51 RAM Replacement, Keyboard: étape 1, image 2 de 3 Asus R541UA-RB51 RAM Replacement, Keyboard: étape 1, image 3 de 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 RAM Replacement: étape 2, image 1 de 2 Asus R541UA-RB51 RAM Replacement: étape 2, image 2 de 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 RAM Replacement: étape 3, image 1 de 2 Asus R541UA-RB51 RAM Replacement: étape 3, image 2 de 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 RAM Replacement, CD Drive: étape 4, image 1 de 1
    • Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
  5. Asus R541UA-RB51 RAM Replacement: étape 5, image 1 de 2 Asus R541UA-RB51 RAM Replacement: étape 5, image 2 de 2
    • Gently slide the CD drive away and pull up to remove it from the computer.
  6. Asus R541UA-RB51 RAM Replacement, Hard Drive: étape 6, image 1 de 2 Asus R541UA-RB51 RAM Replacement, Hard Drive: étape 6, image 2 de 2
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
  7. Asus R541UA-RB51 RAM Replacement, RAM: étape 7, image 1 de 1
    • Remove all fourteen 4.3 mm screws from the motherboard. Use a Phillips #1 screwdriver to remove the screws.
  8. Asus R541UA-RB51 RAM Replacement: étape 8, image 1 de 3 Asus R541UA-RB51 RAM Replacement: étape 8, image 2 de 3 Asus R541UA-RB51 RAM Replacement: étape 8, image 3 de 3
    • Unplug the three connections from the top of the motherboard.
    • Lift up at an angle to remove the motherboard from the computer. Take caution when lifting the areas where the USB ports are located. They are in small slots that exit the computer's main body. They will need to be slid through these slots to remove the motherboard.
  9. Asus R541UA-RB51 RAM Replacement: étape 9, image 1 de 3 Asus R541UA-RB51 RAM Replacement: étape 9, image 2 de 3 Asus R541UA-RB51 RAM Replacement: étape 9, image 3 de 3
    • Locate the RAM slot on the underside of the motherboard. This device did not have a RAM card so a piece of cardboard was used as a substitute.
    • Replace the current card with the new RAM card.
2 autres ont terminé cette réparation.
Drew Singleton
Membre depuis le 08/31/18
359 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 29
Total : 2,067
