Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG Ally Triggers Replacement
Ce dont vous avez besoin
    1. Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: étape 1, image 1 de 3 Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: étape 1, image 2 de 3 Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: étape 1, image 3 de 3
      • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Completely power off your device and unplug all cables.
      • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
      Demander à FixBot
      Ajouter un commentaire
    1. Asus ROG Ally Triggers Replacement, Unfasten the back cover: étape 2, image 1 de 2 Asus ROG Ally Triggers Replacement, Unfasten the back cover: étape 2, image 2 de 2
      Outil utilisé dans cette étape :
      FixMat
      $36.95
      • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
      • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
      • Don't try to remove this screw.
      Demander à FixBot
    2. Asus ROG Ally Triggers Replacement, Insert an opening pick: étape 3, image 1 de 3 Asus ROG Ally Triggers Replacement, Insert an opening pick: étape 3, image 2 de 3 Asus ROG Ally Triggers Replacement, Insert an opening pick: étape 3, image 3 de 3
      • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
      • Angle the pick upward and push it under the back cover.
      Demander à FixBot
    3. Asus ROG Ally Triggers Replacement, Release the back cover's clips: étape 4, image 1 de 3 Asus ROG Ally Triggers Replacement, Release the back cover's clips: étape 4, image 2 de 3 Asus ROG Ally Triggers Replacement, Release the back cover's clips: étape 4, image 3 de 3
      • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
      • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
      • Keep the pick at an upward angle under the back cover to help release the clips.
      Demander à FixBot
    4. Asus ROG Ally Triggers Replacement, Remove the back cover: étape 5, image 1 de 3 Asus ROG Ally Triggers Replacement, Remove the back cover: étape 5, image 2 de 3 Asus ROG Ally Triggers Replacement, Remove the back cover: étape 5, image 3 de 3
      • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
      • Remove the back cover.
      • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
      Demander à FixBot
    1. Asus ROG Ally Triggers Replacement, Unfasten the triggers: étape 6, image 1 de 3 Asus ROG Ally Triggers Replacement, Unfasten the triggers: étape 6, image 2 de 3 Asus ROG Ally Triggers Replacement, Unfasten the triggers: étape 6, image 3 de 3
      • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing each trigger (four screws total).
      Demander à FixBot
    2. Asus ROG Ally Triggers Replacement, Remove the triggers: étape 7, image 1 de 3 Asus ROG Ally Triggers Replacement, Remove the triggers: étape 7, image 2 de 3 Asus ROG Ally Triggers Replacement, Remove the triggers: étape 7, image 3 de 3
      • Pull the triggers straight up and out of their recesses to remove them.
      Demander à FixBot
    3. Asus ROG Ally Triggers Replacement, Trigger installation: étape 8, image 1 de 1
      • During reassembly:
      • Compress the trigger and firmly push it into place on the chassis so the cutouts on the hinge go over their alignment posts. The trigger should stay in place.
      • Keep the trigger compressed and install the two screws.
      • Test the trigger before continuing reassembly. If it's not working properly, remove the trigger and make sure it's properly aligned on the hinge.
      Demander à FixBot
    1. Asus ROG Ally Triggers Replacement, Unclip the triggers: étape 9, image 1 de 3 Asus ROG Ally Triggers Replacement, Unclip the triggers: étape 9, image 2 de 3 Asus ROG Ally Triggers Replacement, Unclip the triggers: étape 9, image 3 de 3
      • Two plastic clips secure each trigger to its hinge.
      • Carefully pull the trigger away from the hinge one side at a time to detach both clips.
      • To install a trigger on its hinge:
      • Make sure the middle section of the spring is looped over the tab on the hinge with the bent ends facing down.
      • With the trigger on the opposite side of the hinge screw-holes, clip it into place so the coiled parts of the spring are between the trigger clips.
      • The trigger should compress and spring back when you press it down.
      Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
198 722 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
59 744 tutoriels rédigés
4 commentaires de tutoriel
Ou trouvons nous les pièces de remplacement
Alien TOYS AlienTOYS - Réponse Partager
Is this the same part as the Ally X?
MightyCreator - Réponse Partager
So there's no wires going to the trigger assembly, how is the trigger depression being detected?? It's the joystick assembly detecting it somehow, right?? I replaced the stick with a hall effect and now the trigger isn't working on that same side.
Eric Birecki - Réponse Partager
There is electromagnetic interference between the trigger and joystick. You need to use some shielding paper.
Dusán Kricskovics - Réponse Partager
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 96
30 derniers jours : 470
Total : 11,228
