Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG G20CB CPU Replacement
Ce dont vous avez besoin
  1. Asus ROG G20CB CPU Replacement, Fan: étape 1, image 1 de 2 Asus ROG G20CB CPU Replacement, Fan: étape 1, image 2 de 2
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus ROG G20CB CPU Replacement: étape 2, image 1 de 1
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    Demander à FixBot
  3. Asus ROG G20CB CPU Replacement: étape 3, image 1 de 1
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
    Demander à FixBot
  4. Asus ROG G20CB CPU Replacement: étape 4, image 1 de 1
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
    Demander à FixBot
  5. Asus ROG G20CB CPU Replacement: étape 5, image 1 de 1
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    Demander à FixBot
  6. Asus ROG G20CB CPU Replacement: étape 6, image 1 de 1
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    Demander à FixBot
  7. Asus ROG G20CB CPU Replacement, CPU Cooler: étape 7, image 1 de 1
    • Remove the 4.6 mm Phillips screw that secures the optical drive.
    Demander à FixBot
  8. Asus ROG G20CB CPU Replacement: étape 8, image 1 de 1
    • Push the optical drive out of the chassis.
    Demander à FixBot
  9. Asus ROG G20CB CPU Replacement: étape 9, image 1 de 1
    • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
    • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
    Demander à FixBot
  10. Asus ROG G20CB CPU Replacement: étape 10, image 1 de 1
    • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
    • Lift the CPU cooler out of the system.
    • Be sure to apply fresh thermal paste before reinstalling a cooler.
    Demander à FixBot
  11. Asus ROG G20CB CPU Replacement, CPU: étape 11, image 1 de 1
    • Locate the CPU socket retention arm next to the processor.
    • Push the arm down and out, then lift it upward to release the CPU cover.
    Demander à FixBot
  12. Asus ROG G20CB CPU Replacement: étape 12, image 1 de 1
    • Gently lift the CPU straight out of the socket.
    • Handle the CPU by its edges. Do not touch the bottom pins or contacts to avoid damage.
    Demander à FixBot
  13. Asus ROG G20CB CPU Replacement: étape 13, image 1 de 1
    • Reassembly tip: When installing a new CPU make sure to align the gold triangle with the white circle on the motherboard.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
Membre depuis le 03/21/25
361 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Botvin Spring 2025 Membre de l'équipe UMass Dartmouth, Team 3-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G3
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 49
Total : 467
