Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG G20CB Graphics Card Replacement
Ce dont vous avez besoin
  1. Asus ROG G20CB Graphics Card Replacement, Fan: étape 1, image 1 de 2 Asus ROG G20CB Graphics Card Replacement, Fan: étape 1, image 2 de 2
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus ROG G20CB Graphics Card Replacement: étape 2, image 1 de 1
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    Demander à FixBot
  3. Asus ROG G20CB Graphics Card Replacement: étape 3, image 1 de 1
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
    Demander à FixBot
  4. Asus ROG G20CB Graphics Card Replacement: étape 4, image 1 de 1
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
    Demander à FixBot
  5. Asus ROG G20CB Graphics Card Replacement: étape 5, image 1 de 1
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    Demander à FixBot
  6. Asus ROG G20CB Graphics Card Replacement: étape 6, image 1 de 1
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    Demander à FixBot
  7. Asus ROG G20CB Graphics Card Replacement, Graphics Card: étape 7, image 1 de 1
    • Remove the three 4.6 mm Phillips screws from the graphics card housing.
    Demander à FixBot
  8. Asus ROG G20CB Graphics Card Replacement: étape 8, image 1 de 1
    • Pull the graphics card housing out of the case.
    • Be mindful of the 8-pin power cable connected to the graphics card.
    Demander à FixBot
  9. Asus ROG G20CB Graphics Card Replacement: étape 9, image 1 de 1
    • Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
    Demander à FixBot
  10. Asus ROG G20CB Graphics Card Replacement: étape 10, image 1 de 1
    • Remove the 3.7 mm Phillips screw from the graphics card and its housing.
    Demander à FixBot
  11. Asus ROG G20CB Graphics Card Replacement: étape 11, image 1 de 1
    • Slide the graphics card out of the housing.
    Demander à FixBot
  12. Asus ROG G20CB Graphics Card Replacement: étape 12, image 1 de 1
    • Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
    • This riser will need to be used with the new graphics card in order to be installed in this system.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
AdamGadd
Membre depuis le 03/21/25
349 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Botvin Spring 2025 Membre de l'équipe UMass Dartmouth, Team 3-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G3
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 78
Total : 510
