Aller au contenu principal
Asus ROG G56JK CD Drive Replacement
Ce dont vous avez besoin
  1. Asus ROG G56JK CD Drive Replacement, Battery: étape 1, image 1 de 2 Asus ROG G56JK CD Drive Replacement, Battery: étape 1, image 2 de 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: étape 2, image 1 de 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: étape 3, image 1 de 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: étape 4, image 1 de 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: étape 5, image 1 de 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: étape 6, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: étape 7, image 1 de 1
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Brandon Wells
Membre depuis le 09/26/18
253 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 699
