Aller au contenu principal
Introduction
If you need to reinstall new RAM slots, you can access the RAM using this guide. You may need to replace RAM if your computer is not running fast enough or has insufficient memory. For this guide, you will need a plastic opening tool and a flathead screwdriver. You will not need to do any difficult steps, but pry the RAM clips carefully.
Pièces
Aucune pièce spécifiée.
  1. Place the device upside down. Unscrew the big metal screw with a flathead screwdriver. Remove the cover using the plastic opening tool.
    • Place the device upside down.
    • Unscrew the big metal screw with a flathead screwdriver.
    • Remove the cover using the plastic opening tool.
  2. Fix Kits pour iPhone X
    Finie la garantie ? Pas de soucis, nous avons de quoi réparer.
    Acheter maintenant
    Acheter maintenant
  3. Pry the clips holding the RAM on both sides. Pry the clips holding the RAM on both sides.
    • Pry the clips holding the RAM on both sides.
  4. Gently lift the RAM and pull it out. Gently lift the RAM and pull it out. Gently lift the RAM and pull it out.
    • Gently lift the RAM and pull it out.
Jackson Reynolds
Membre depuis le 18/09/2018
331 Réputation
3 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 66
