Aller au contenu principal
Asus ROG G750JH-DB71 Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: étape 2, image 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: étape 2, image 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: étape 2, image 3 de 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: étape 3, image 3 de 3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: étape 4, image 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: étape 4, image 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: étape 4, image 3 de 3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
Devin Medeiros
Membre depuis le 10/25/22
219 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 5-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 153
