Aller au contenu principal
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
Ce dont vous avez besoin
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: étape 1, image 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: étape 1, image 2 de 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 2, image 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 2, image 2 de 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 3, image 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 3, image 2 de 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 4, image 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 4, image 2 de 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 5, image 1 de 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 5, image 2 de 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 5, image 3 de 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: étape 6, image 1 de 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Tanner
Membre depuis le 09/21/18
919 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 397
