Aller au contenu principal
Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement
Ce dont vous avez besoin
  1. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: étape 1, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: étape 1, image 2 de 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 2, image 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 2, image 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 2, image 3 de 3
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 3, image 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 3, image 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 3, image 3 de 3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 4, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 4, image 2 de 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 5, image 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 5, image 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 5, image 3 de 3
    • Remove the screws holding the hard drives in place using a Phillips 1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 6, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 7, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 7, image 2 de 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 8, image 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 8, image 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 8, image 3 de 3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 9, image 1 de 1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 10, image 1 de 1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 11, image 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 11, image 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 11, image 3 de 3
    • Use a metal spudger to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 12, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 12, image 2 de 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 13, image 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: étape 13, image 2 de 2
    • Use a pair of tweezers to undo each of the two ribbon connectors.
    • The Left and right button is now completely disconnected from the laptop and you can remove it.
3 autres ont terminé cette réparation.
Équipe
IUPUI, Team S8-G8, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 1,136
