Aller au contenu principal
Asus ROG GL551J Optical Drive Replacement
Ce dont vous avez besoin
  1. Asus ROG GL551J Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
    could provide a link on where to purchase screens or a link for this specific model, they are hard to find
    Anika Rozeboom - Réponse
  2. Asus ROG GL551J Optical Drive Replacement: étape 2, image 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Optical Drive Replacement: étape 3, image 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J Optical Drive Replacement, Optical Drive: étape 4, image 1 de 2 Asus ROG GL551J Optical Drive Replacement, Optical Drive: étape 4, image 2 de 2
    • Locate and unscrew the screw which connects the optical drive to the chassis
  5. Asus ROG GL551J Optical Drive Replacement: étape 5, image 1 de 1
    • Grasp the edge of the optical drive
  6. Asus ROG GL551J Optical Drive Replacement: étape 6, image 1 de 1
    • Pull on the optical drive gently. With little resistance, the optical drive should just slide out
4 autres ont terminé cette réparation.
Philip Muino
Membre depuis le 02/15/17
179 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 membres
5 tutoriels rédigés
Un commentaire
ok.so , if someone had replaced the dvd rom with a hard disk drive i nust do the same for replace the drive?
anix - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 1,974
