Aller au contenu principal
Asus ROG GL551J RAM Replacement
Ce dont vous avez besoin
  1. Asus ROG GL551J RAM Replacement, Battery: étape 1, image 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J RAM Replacement: étape 2, image 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J RAM Replacement: étape 3, image 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J RAM Replacement, RAM: étape 4, image 1 de 2 Asus ROG GL551J RAM Replacement, RAM: étape 4, image 2 de 2
    • Remove the two screws securing the access panel to the laptop.
  5. Asus ROG GL551J RAM Replacement: étape 5, image 1 de 2 Asus ROG GL551J RAM Replacement: étape 5, image 2 de 2
    • Slide access panel out and remove.
  6. Asus ROG GL551J RAM Replacement: étape 6, image 1 de 2 Asus ROG GL551J RAM Replacement: étape 6, image 2 de 2
    • Place thumbs on the locking tabs of both sides of the RAM stick and push outwards to unlock.
  7. Asus ROG GL551J RAM Replacement: étape 7, image 1 de 1
    • RAM should pop up at about 45 degrees. Pull outwards with fingers on the side of the RAM to remove.
Congratulations, you now know how to replace the RAM sticks for your Asus ROG GL551J laptop, and this process can also apply to other similar laptops that you may acquire in the future.
3 autres ont terminé cette réparation.
Jason Nguyen
Membre depuis le 02/20/17
356 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,434
