Aller au contenu principal
Asus ROG GL551J Screen Replacement
Ce dont vous avez besoin
  1. Asus ROG GL551J Screen Replacement, Battery: étape 1, image 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: étape 2, image 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: étape 3, image 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: étape 4, image 1 de 2 Asus ROG GL551J Screen Replacement, Screen: étape 4, image 2 de 2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: étape 5, image 1 de 2 Asus ROG GL551J Screen Replacement: étape 5, image 2 de 2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: étape 6, image 1 de 2 Asus ROG GL551J Screen Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: étape 7, image 1 de 1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: étape 8, image 1 de 2 Asus ROG GL551J Screen Replacement: étape 8, image 2 de 2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Thien Vu
Membre depuis le 02/15/17
412 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 membres
5 tutoriels rédigés
Un commentaire
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 21
Total : 3,034
