Aller au contenu principal
Asus ROG Strix GL553VD Battery Replacement
Ce dont vous avez besoin
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: étape 1, image 1 de 2 Asus ROG Strix GL553VD Battery Replacement, Battery: étape 1, image 2 de 2
    • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
  2. Asus ROG Strix GL553VD Battery Replacement: étape 2, image 1 de 2 Asus ROG Strix GL553VD Battery Replacement: étape 2, image 2 de 2
    • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
  3. Asus ROG Strix GL553VD Battery Replacement: étape 3, image 1 de 3 Asus ROG Strix GL553VD Battery Replacement: étape 3, image 2 de 3 Asus ROG Strix GL553VD Battery Replacement: étape 3, image 3 de 3
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: étape 4, image 1 de 3 Asus ROG Strix GL553VD Battery Replacement: étape 4, image 2 de 3 Asus ROG Strix GL553VD Battery Replacement: étape 4, image 3 de 3
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: étape 5, image 1 de 1
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
4 autres ont terminé cette réparation.
Mahmoud Mehdi
Membre depuis le 09/20/20
247 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G89, Woodhouse Fall 2020 Membre de l'équipe York University, Team S1-G89, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G89
1 membre
1 tutoriel rédigé
Un commentaire
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 62
Total : 4,484
