Introduction
Should your Asus ROG Strix GL702VM-BHI7N09 Gaming Laptop suffer from short battery life or outright battery failure this guide may be used to replace it.
The battery enables the laptop to be used without its charger cord. Battery failure prevents the laptop from functioning without its charger. Replacing the battery will restore this capability.
No advanced skills are needed for this procedure.
Ce dont vous avez besoin
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
6 autres ont terminé cette réparation.
Un commentaire
Cheers mate! Worked like a %#*@. Built lots of PCs in my time but this is the first time I’ve taken a laptop apart. I should mention: there are 4 screws holding the battery in rather than the 1 you mention in this guide.
