Introduction
The motherboard is a critical part of any computer, housing the central processor unit that data flows through. The Asus ROG Strix GL702VM-BHI7N09 gaming laptop is no exception and cannot function without a working motherboard. The guide below displays how to properly replace this component. Before starting the replacement of the motherboard, it is important to have some prior background knowledge about the components of a gaming laptop. It is also vital to power off the device, remove it from any external charging cable and disconnect or remove the battery prior to beginning the repair.
Ce dont vous avez besoin
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
Disconnect the speakers connectors located in each of the bottom corners.
Gently pull the wire up from the motherboard.
Once the wire is disconnected, pull the speaker out.
