Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Ce dont vous avez besoin
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): étape 1, image 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): étape 1, image 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): étape 1, image 3 de 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
    Demander à FixBot
    Ajouter un commentaire
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 2, image 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 2, image 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 2, image 3 de 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
    Demander à FixBot
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 3, image 1 de 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 3, image 2 de 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
    Demander à FixBot
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 4, image 1 de 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
    Demander à FixBot
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 5, image 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 5, image 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 5, image 3 de 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
    Demander à FixBot
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 6, image 1 de 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
    Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 35
Total : 2,320
