Aller au contenu principal
Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
Ce dont vous avez besoin
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: étape 1, image 1 de 2 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: étape 1, image 2 de 2
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 2, image 1 de 1
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 3, image 1 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 3, image 2 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 3, image 3 de 3
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 4, image 1 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 4, image 2 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 4, image 3 de 3
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 5, image 1 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 5, image 2 de 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: étape 5, image 3 de 3
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
7 autres ont terminé cette réparation.
Christian Clark
Membre depuis le 02/22/22
205 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 33
30 derniers jours : 157
Total : 3,140
