Aller au contenu principal
Asus ROG ZX50VW-BH17N10 Fan Replacement
Ce dont vous avez besoin
  1. Asus ROG ZX50VW-BH17N10 Fan Replacement, Fan: étape 1, image 1 de 1
    • Remove the 1.6 mm and 9 mm screws from the back panel using the Phillips #1 screwdriver.
  2. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 2, image 1 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 2, image 2 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 2, image 3 de 3
    • Use the metal spudger to pry the back panel off.
  3. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 3, image 1 de 1
    • The following screws can be removed using the Phillips #1 screwdriver.
    • Remove the four 9 mm screws from the hard drive and use the black pull tab to remove it.
    • Remove the five 1.6 mm screws and three 9 mm screws from perimeter of the laptop's base.
    • Remove the 9 mm screw next to the RAM.
    • Flip the computer right-side up .
    • Caution when flipping the computer. Components may shift around and the hard drive will fall out if not removed prior to flipping.
  4. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 4, image 1 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 4, image 2 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 4, image 3 de 3
    • Gently pry the keyboard off being careful not to tug at any of the inner ribbons.
    • Keep the pry tool shallow. The ribbons are very fragile and can be severed easily.
    • Detach the three ribbons connecting the motherboard and the keyboard. Do this by flipping up the white latch and pulling the ribbon out. There should be one latch per ribbon.
  5. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 5, image 1 de 1
    • Gently remove the the keyboard.
    • Caution. There should be nothing attached to the keyboard at this point.
  6. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 6, image 1 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 6, image 2 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 6, image 3 de 3
    • Unscrew the three Phillips #1 screws from the motherboard.
  7. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 7, image 1 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 7, image 2 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Detach the black and white plugs from the motherboard.
    • Remove the wireless AC chip from the motherboard using the tweezers.
    • Detach the last ribbon from the motherboard.
    • Using a metal spudger can severely damage the inner components of your device.
  8. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 8, image 1 de 1
    • Remove the three 7 mm screws attached to the fan using the Phillips #1 screwdriver.
  9. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 9, image 1 de 1
    • Take hold of the right side of the mother board and lift upwards.
    • At the same time, hold the fan in place as the motherboard is lifted upward.
    • Be sure that no other ribbons or wires are attached to the motherboard at this point.
  10. Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 10, image 1 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 10, image 2 de 3 Asus ROG ZX50VW-BH17N10 Fan Replacement: étape 10, image 3 de 3
    • Carefully flip the motherboard over and place it down flat.
    • Detach the plug from the motherboard and remove the fan.
    • Using the metal spudger may severely damage the internal components of a device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 358
