Aller au contenu principal
Asus ROG Zephyrus G14 Thermal Paste Replacement
Ce dont vous avez besoin
  1. Asus ROG Zephyrus G14 Thermal Paste Replacement, Opening the device: étape 1, image 1 de 1
    • Start by unscrewing the bottom case. There are two different size screws. One long one short.
    • The ones marked in red are the short ones. As for the ones in orange are the long ones.
  2. Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: étape 2, image 1 de 2 Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: étape 2, image 2 de 2
    • Using a plastic spudger push back the retaining clasp for the battery plug. It is a sliding motion so push it to the right with the battery closest to you.
  3. Asus ROG Zephyrus G14 Thermal Paste Replacement, Removing the cooler: étape 3, image 1 de 1
    • Marked in red and orange are the screws that hold on the cooler. They are all the same size but I would still keep track of if it was holding on a fan or a block.
    • Marked in yellow are the power and signal wires for the fans. Using a plastic spudger slowly walk the male plug out of its socket.
    • Using the same spudger's flat side pry around the two dies. The old thermal paste will fight back so take your time.
    • Carefully remove the display cable concealed with plastic on the leftmost side of the board - marked in blue.
    • Remove the wifi coax cables (black and white) concealed with plastic to the rightmost side of the board - marked in pink.
    • Only then the cooling unit can be freely removed.
  4. Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: étape 4, image 1 de 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: étape 4, image 2 de 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: étape 4, image 3 de 3
    • You can see where the thermal paste was so make sure to apply it on the same surfaces.
    • I have marked two small parts that are easy to miss.
    • I used 70% rubbing alcohol, tissues, and the flat end of a spudger to remove the old paste.
    • I used a plastic spudger to spread the paste on the chips to make sure that it will make full contact.
    • Replace the cooler by reversing the steps in step 3.
  5. Asus ROG Zephyrus G14 Thermal Paste Replacement, The bottom case: étape 6, image 1 de 1
    • Button up the device by placing and screwing on the bottom case.
    • The screws marked in orange are long. The ones marked in red are short.
  6. Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: étape 7, image 1 de 2 Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: étape 7, image 2 de 2
    • Before new paste.
  7. Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: étape 8, image 1 de 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: étape 8, image 2 de 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: étape 8, image 3 de 3
    • After new Thermal paste.
    • For the testing, I used 3D mark time spy without the demo. As well as a custom fan curve. The profile was set to turbo for both runs.
12 autres ont terminé cette réparation.
jon bush
Membre depuis le 11/19/20
527 Réputation
1 tutoriel rédigé
6 commentaires
I used metal tweezers and my laptop won’t turn on now. What did I do?
Mason - Réponse
Did you manage to get an answer to this? I didn't use metal tweezers but my laptop won't turn on and it's blinking as if it's trying to run but it can't!
OVO Architects -
Open up chips and look if there are cracks on chips, if there are, then you got a dead chip.
hazard4636 -
I followed this and even used ifixit tools and now my laptop won't boot. No bios, no charge light, no cpu light, no fans. I followed it exactly, grounded myself, didn't touch the motherboard, didn't even get up as to not accidentally generate static, worked on concrete and a wooden table, none of the connections are loose or damaged. It just won't turn on. What happened and how can I fix it?
Daniel Carbaugh (Danny) - Réponse
I’d go in and check for any connections on the motherboard that you may have missed and also look out for any broken ones. Try reseating any connections such as the battery connector and display cable.
Sergiu Trinca -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 129
30 derniers jours : 747
Total : 18,885
