Aller au contenu principal
Asus TF300T Tablet Speaker Replacement
Ce dont vous avez besoin
  1. Asus TF300T Tablet Speaker Replacement, Speaker: étape 1, image 1 de 2 Asus TF300T Tablet Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Disconnect the dock and make sure the power is turned off.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reach the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Speaker Replacement: étape 2, image 1 de 3 Asus TF300T Tablet Speaker Replacement: étape 2, image 2 de 3 Asus TF300T Tablet Speaker Replacement: étape 2, image 3 de 3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Speaker Replacement: étape 3, image 1 de 2 Asus TF300T Tablet Speaker Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
    • Use the same screwdriver to remove two 3mm screws connecting the clips.
    • Use tweezers to remove two wires connected from the battery to the motherboard.
    • Use the spudger to remove he battery from the case.
  4. Asus TF300T Tablet Speaker Replacement: étape 4, image 1 de 3 Asus TF300T Tablet Speaker Replacement: étape 4, image 2 de 3 Asus TF300T Tablet Speaker Replacement: étape 4, image 3 de 3
    • Use the tweezers to remove the speaker unit from its clip by pulling on the white plug.
    • Use a Phillips #00 Screwdriver to remove all of the 3mm screws that is connected with the speaker.
    • Use plastic opening tool to take out the speaker.
Khairuz Zaki Md Rujhan
Membre depuis le 05/22/17
461 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S2-G2, Wilson Summer 2017 Membre de l'équipe IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 349
