Aller au contenu principal
Asus TUF Gaming FX705G Fan Replacement
Ce dont vous avez besoin
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: étape 1, image 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: étape 2, image 1 de 2 Asus TUF Gaming FX705G Fan Replacement: étape 2, image 2 de 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: étape 3, image 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Battery: étape 3, image 2 de 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: étape 4, image 1 de 2 Asus TUF Gaming FX705G Fan Replacement: étape 4, image 2 de 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: étape 5, image 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Fan: étape 5, image 2 de 2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: étape 6, image 1 de 3 Asus TUF Gaming FX705G Fan Replacement: étape 6, image 2 de 3 Asus TUF Gaming FX705G Fan Replacement: étape 6, image 3 de 3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: étape 7, image 1 de 3 Asus TUF Gaming FX705G Fan Replacement: étape 7, image 2 de 3 Asus TUF Gaming FX705G Fan Replacement: étape 7, image 3 de 3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
15 autres ont terminé cette réparation.
Britney Smit
Membre depuis le 10/15/19
477 Réputation
2 tutoriels rédigés
3 commentaires
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - Réponse
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - Réponse
This was very helpful. Thank you
Sue Olmos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 142
Total : 15,698
