Aller au contenu principal
Asus TUF Gaming FX705G M.2 SSD Replacement
Ce dont vous avez besoin
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: étape 1, image 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: étape 2, image 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement: étape 2, image 2 de 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: étape 3, image 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: étape 3, image 2 de 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: étape 4, image 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement: étape 4, image 2 de 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: étape 5, image 1 de 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: étape 6, image 1 de 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
3 autres ont terminé cette réparation.
Emma Despres
Membre depuis le 10/15/19
231 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 45
Total : 4,087
