Aller au contenu principal
Asus TUF Gaming FX705G Track Pad Replacement
Ce dont vous avez besoin
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: étape 1, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: étape 2, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement: étape 2, image 2 de 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: étape 3, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement, Battery: étape 3, image 2 de 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: étape 4, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement: étape 4, image 2 de 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: étape 5, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: étape 5, image 2 de 2
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: étape 6, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement: étape 6, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: étape 7, image 1 de 2 Asus TUF Gaming FX705G Track Pad Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: étape 8, image 1 de 3 Asus TUF Gaming FX705G Track Pad Replacement: étape 8, image 2 de 3 Asus TUF Gaming FX705G Track Pad Replacement: étape 8, image 3 de 3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
Britney Smit
Membre depuis le 10/15/19
501 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 25
Total : 2,078
