Introduction
This guide teaches you how to remove and then replace the battery from your Asus Transformer Book T100TAF. This will bring back longevity to the device’s battery life. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
Ce dont vous avez besoin
Detach the keyboard from the screen by depressing the silver button the hinge and pulling upwards on the tablet.
To reassemble your device, follow these instructions in reverse order. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
5 autres ont terminé cette réparation.
3 commentaires
Bonjour quelqu’un sait comment retirer la batterie d’origine de l’ordinateur (au niveau de la connection)?
Merci
