Aller au contenu principal
Asus Transformer Flip Book TP200S Battery Replacement
Ce dont vous avez besoin
  1. Asus Transformer Flip Book TP200S Battery Replacement, Battery: étape 1, image 1 de 2 Asus Transformer Flip Book TP200S Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S Battery Replacement: étape 2, image 1 de 1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S Battery Replacement: étape 3, image 1 de 1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S Battery Replacement: étape 4, image 1 de 2 Asus Transformer Flip Book TP200S Battery Replacement: étape 4, image 2 de 2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
2 autres ont terminé cette réparation.
Alejandro Lopez
Membre depuis le 02/15/18
662 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G2, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 membres
6 tutoriels rédigés
3 commentaires
how if my laptop not charge but the battery have replace before
Chen _El - Réponse
its tooeasy! Thank You!
fotonngn - Réponse
Its too easy! Tnks!
fotonngn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 21
Total : 3,087
