Introduction
This guide demonstrates how to replace the cooling fan by first removing the motherboard.
Ce dont vous avez besoin
Remove the hard drive cover.
Unscrew one 8mm Phillips #00 screw.
Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
Unscrew the one 8mm screw using a Phillips #00.
Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
Use a Phillips screwdriver to loosen the four screws holding the component in place.
