Aller au contenu principal
Asus U47VC-DS51 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus U47VC-DS51 Motherboard Replacement, Hard Drive: étape 1, image 1 de 3 Asus U47VC-DS51 Motherboard Replacement, Hard Drive: étape 1, image 2 de 3 Asus U47VC-DS51 Motherboard Replacement, Hard Drive: étape 1, image 3 de 3
    • Remove the hard drive cover.
    • Unscrew one 8mm Phillips #00 screw.
    • Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
  2. Asus U47VC-DS51 Motherboard Replacement: étape 2, image 1 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 2, image 2 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 2, image 3 de 3
    • Remove the hard drive.
    • Unscrew the four 3mm Phillips #00 screws.
    • Pull the hard drive's black tab away from the laptop to free it.
  3. Asus U47VC-DS51 Motherboard Replacement, Keyboard: étape 3, image 1 de 2 Asus U47VC-DS51 Motherboard Replacement, Keyboard: étape 3, image 2 de 2
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  4. Asus U47VC-DS51 Motherboard Replacement: étape 4, image 1 de 2 Asus U47VC-DS51 Motherboard Replacement: étape 4, image 2 de 2
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
  5. Asus U47VC-DS51 Motherboard Replacement: étape 5, image 1 de 2 Asus U47VC-DS51 Motherboard Replacement: étape 5, image 2 de 2
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  6. Asus U47VC-DS51 Motherboard Replacement: étape 6, image 1 de 2 Asus U47VC-DS51 Motherboard Replacement: étape 6, image 2 de 2
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
  7. Asus U47VC-DS51 Motherboard Replacement, Motherboard: étape 7, image 1 de 3 Asus U47VC-DS51 Motherboard Replacement, Motherboard: étape 7, image 2 de 3 Asus U47VC-DS51 Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Unscrew the one 8mm screw using a Phillips #00.
    • Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
  8. Asus U47VC-DS51 Motherboard Replacement: étape 8, image 1 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 8, image 2 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 8, image 3 de 3
    • Using the black spudger, slowly lift up on the cable connectors and pull them away from the connectors.
    • Repeat steps on both cables.
    • Unscrew the 12 8mm screws using a Phillips #00 screwdriver.
  9. Asus U47VC-DS51 Motherboard Replacement: étape 9, image 1 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 9, image 2 de 3 Asus U47VC-DS51 Motherboard Replacement: étape 9, image 3 de 3
    • Lift up on the motherboard and disengage the two connectors.
    • Disconnect the cooling fan connector.
    • Unscrew the 7 8mm screws holding in the cooling fan using a Phillips #00 screwdriver.
Murphy Villegas
Membre depuis le 01/19/17
207 Réputation
2 tutoriels rédigés
Un commentaire
Step#3, You need to remove a total of 13 screws from the bottom of the laptop BEFORE prying the keyboard section off the laptop. See pics https://imgur.com/a/h5d1zJ1
danwat1234 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 636
