Aller au contenu principal
Asus U56E-BBL6 Optical Drive Replacement
Ce dont vous avez besoin
  1. Asus U56E-BBL6 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Optical Drive Replacement: étape 2, image 1 de 1
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Optical Drive Replacement, Back Panel: étape 3, image 1 de 2 Asus U56E-BBL6 Optical Drive Replacement, Back Panel: étape 3, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Optical Drive Replacement: étape 4, image 1 de 1
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Optical Drive Replacement, RAM: étape 5, image 1 de 1
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Optical Drive Replacement: étape 6, image 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: étape 6, image 2 de 2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Optical Drive Replacement: étape 7, image 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: étape 7, image 2 de 2
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Optical Drive Replacement, Keyboard: étape 8, image 1 de 1
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Optical Drive Replacement: étape 9, image 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: étape 9, image 2 de 2
  10. Asus U56E-BBL6 Optical Drive Replacement: étape 10, image 1 de 1
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Optical Drive Replacement: étape 11, image 1 de 1
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Optical Drive Replacement: étape 12, image 1 de 1
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Optical Drive Replacement: étape 13, image 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: étape 13, image 2 de 2
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Optical Drive Replacement, Optical Drive: étape 14, image 1 de 1
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Optical Drive Replacement: étape 15, image 1 de 1
    • Remove the optical drive by sliding it out from the case.
Josiah Allard
Membre depuis le 10/26/18
733 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G8, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G8, Peak Fall 2018
UMASSD-PEAK-F18S2G8
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 206
