Introduction
The keyboard is the device used to input data, text, and commands through to your laptop. If the keyboard is not responding or inputs incorrectly, you may have to replace your keyboard. This guide will show you how to replace the keyboard.
Ce dont vous avez besoin
Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
Outil utilisé dans cette étape :Plastic Cards$2.99
Gently pry the keyboard up. This will allow you to unclip the keyboard.
Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
