Aller au contenu principal
Asus UL80VT Motherboard Replacement
Ce dont vous avez besoin
  1. Asus UL80VT Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: étape 2, image 1 de 2 Asus UL80VT Motherboard Replacement: étape 2, image 2 de 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: étape 3, image 1 de 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: étape 4, image 1 de 3 Asus UL80VT Motherboard Replacement, Hard Drive: étape 4, image 2 de 3 Asus UL80VT Motherboard Replacement, Hard Drive: étape 4, image 3 de 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: étape 5, image 1 de 2 Asus UL80VT Motherboard Replacement: étape 5, image 2 de 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: étape 6, image 1 de 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: étape 7, image 1 de 3 Asus UL80VT Motherboard Replacement: étape 7, image 2 de 3 Asus UL80VT Motherboard Replacement: étape 7, image 3 de 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: étape 8, image 1 de 2 Asus UL80VT Motherboard Replacement, Keyboard: étape 8, image 2 de 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: étape 9, image 1 de 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: étape 10, image 1 de 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: étape 11, image 1 de 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: étape 12, image 1 de 2 Asus UL80VT Motherboard Replacement: étape 12, image 2 de 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: étape 13, image 1 de 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: étape 14, image 1 de 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: étape 15, image 1 de 1
    • Lift the motherboard out of the laptop and remove it from the device.
2 autres ont terminé cette réparation.
James DellaMorte
Membre depuis le 03/08/19
660 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 20
Total : 436
