Aller au contenu principal
Asus V500CA-DB51T Battery Replacement
Ce dont vous avez besoin
  1. Asus V500CA-DB51T Battery  Replacement, Battery: étape 1, image 1 de 2 Asus V500CA-DB51T Battery  Replacement, Battery: étape 1, image 2 de 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Battery  Replacement: étape 2, image 1 de 2 Asus V500CA-DB51T Battery  Replacement: étape 2, image 2 de 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Battery  Replacement: étape 3, image 1 de 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Battery  Replacement: étape 4, image 1 de 2 Asus V500CA-DB51T Battery  Replacement: étape 4, image 2 de 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Battery  Replacement: étape 5, image 1 de 3 Asus V500CA-DB51T Battery  Replacement: étape 5, image 2 de 3 Asus V500CA-DB51T Battery  Replacement: étape 5, image 3 de 3
    • Use the opening tool to pop up the battery away from the casing.
Galen P Garofalo
Membre depuis le 10/17/17
670 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S6-G2, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 412
