Introduction
In this guide, you will learn how to replace the WiFi Card found in the Asus V500CA-DB51T. This guide was made to help with replacing a broken or defective WiFi Card, and is an easy repair for any skill level.
Ce dont vous avez besoin
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Locate the section of the device that houses the WiFi Card.
This should be a white, square-shaped object located just above the left end of the battery.
