Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. Place the computer upside down. Using your thumbs, slide both latches away from each other (towards the outside).
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Remove the two highlighted screws. Remove the two highlighted screws.
    • Remove the two highlighted screws.
  3. Pry open case at highlighted area. Actual hard drive is not shown in the image.
    • Pry open case at highlighted area.
    • Actual hard drive is not shown in the image.
  4. Pull out hard drive laterally from slot shown. Pull out hard drive laterally from slot shown.
    • Pull out hard drive laterally from slot shown.
  5. First, remove the highlighted screw (bottom right corner in the picture.) Using any tool that fits into the highlighted hole, carefully push CD/DVD drive out.
    • First, remove the highlighted screw (bottom right corner in the picture.)
    • Using any tool that fits into the highlighted hole, carefully push CD/DVD drive out.
To reassemble your device, just push new CD/DVD driver back in
Jong Park
Membre depuis le 24/06/2010
114 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-9, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,048
