Aller au contenu principal
Asus V6800V Fan Replacement
Ce dont vous avez besoin
  1. Asus V6800V Fan Replacement, Battery: étape 1, image 1 de 2 Asus V6800V Fan Replacement, Battery: étape 1, image 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: étape 2, image 1 de 2 Asus V6800V Fan Replacement, Fan: étape 2, image 2 de 2
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: étape 3, image 1 de 2 Asus V6800V Fan Replacement: étape 3, image 2 de 2
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: étape 4, image 1 de 2 Asus V6800V Fan Replacement: étape 4, image 2 de 2
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: étape 5, image 1 de 2 Asus V6800V Fan Replacement: étape 5, image 2 de 2
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: étape 6, image 1 de 2 Asus V6800V Fan Replacement: étape 6, image 2 de 2
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
Jong Park
Membre depuis le 06/24/10
114 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-9, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 4,998
