Aller au contenu principal
Asus V6800V Keyboard Replacement
Ce dont vous avez besoin
  1. Asus V6800V Keyboard Replacement, Battery: étape 1, image 1 de 2 Asus V6800V Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Keyboard Replacement: étape 3, image 1 de 3 Asus V6800V Keyboard Replacement: étape 3, image 2 de 3 Asus V6800V Keyboard Replacement: étape 3, image 3 de 3
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Keyboard Replacement: étape 4, image 1 de 2 Asus V6800V Keyboard Replacement: étape 4, image 2 de 2
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Steven
Membre depuis le 06/24/10
32 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-9, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 4,971
