Aller au contenu principal
Asus VivoBook E203MA-TBCL432B Motherboard Replacement
Ce dont vous avez besoin
  1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 2, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 2, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 3, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 3, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 3, image 3 de 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: étape 4, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: étape 4, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: étape 4, image 3 de 3
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 5, image 1 de 1
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 6, image 1 de 2 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 6, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 7, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 7, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 7, image 3 de 3
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
  8. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Disconnect the small black and red bundled cable by lifting it directly up from the connector on the motherboard.
  9. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 9, image 1 de 2 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 9, image 2 de 2
    • Disconnect the black ribbon cable in the center of the motherboard by first lifting the black tab and then pulling the cable free.
  10. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 10, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 10, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 10, image 3 de 3
    • Remove the coaxial connector from the motherboard.
    • Grasp the wire close to where it connects to the motherboard.
    • Pull up and away from the motherboard until the connector is no longer attached to the motherboard.
  11. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 11, image 1 de 2 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 11, image 2 de 2
    • At the top of the motherboard there is a connector that is taped in place.
    • Peel back the tape so that it is no longer in contact with the motherboard.
    • Gently pull the connector out from its socket.
  12. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 12, image 1 de 2 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 12, image 2 de 2
    • Now that all the cables are disconnected from the motherboard, you can begin to remove the screws holding the motherboard in place.
    • Use a Philips #0 screwdriver to remove the six 2 mm screws.
  13. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 13, image 1 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 13, image 2 de 3 Asus VivoBook E203MA-TBCL432B Motherboard Replacement: étape 13, image 3 de 3
    • Lift the motherboard away from the computer while allowing the ribbon cable in the middle to fall through its cutout.
7 autres ont terminé cette réparation.
Brad
Membre depuis le 03/20/19
539 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S8G1
3 membres
6 tutoriels rédigés
Un commentaire
Can we have a tutorial on how to remove the storage from it?
CJ-1-2-3 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 39
Total : 2,337
