Aller au contenu principal
Asus VivoBook E203MA-TBCL432B Power Button Replacement
Ce dont vous avez besoin
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: étape 1, image 1 de 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 2, image 1 de 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 2, image 2 de 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 3, image 1 de 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 3, image 2 de 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 3, image 3 de 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: étape 4, image 1 de 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: étape 4, image 2 de 2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 5, image 1 de 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 5, image 2 de 2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: étape 6, image 1 de 1
    • Now that the power button component is free, lift it up and out of the laptop.
Jacob Aubertine
Membre depuis le 03/21/19
470 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S8G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 920
