Introduction
If your Asus VivoBook E203MA-TBCL432B isn’t producing clear audio through its built-in speakers, use this guide to replace the built-in audio speakers.
Properly working speakers should play audio with no distortion to the sound. A faulty speaker will transmit distorted audio or no audio at all.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source. Overall, this is a relatively simple repair that does not require advanced technical skills.
Ce dont vous avez besoin
Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
Insert the iFixit opening tool in between the back panel and the rest of the laptop.
With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
Using the iFixit opening tool, pry up and remove the battery connector from the motherboard.
Using the iFixit opening tool again, carefully wedge the tool under a corner of the speaker connector on the motherboard that is connected by three wires (colored red, black, and white).
Slowly pry the connector up without damaging the motherboard.
