Aller au contenu principal
Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: étape 1, image 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: étape 1, image 2 de 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 3, image 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 3, image 2 de 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 4, image 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 4, image 2 de 2
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 5, image 1 de 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): étape 6, image 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): étape 6, image 2 de 2
    • Remove one 5mm screw using a PH0 Philips screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 7, image 1 de 1
    • Remove the cable by lifting upwards with a pair of tweezers.
  8. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: étape 8, image 1 de 1
    • Remove the WLAN chip by pulling out parallel to the surface.
Bryann Tan
Membre depuis le 09/25/16
838 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Eyestone Fall 2016 Membre de l'équipe USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 174
