Aller au contenu principal
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 2, image 1 de 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 3, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 3, image 2 de 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 5, image 1 de 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 5, image 2 de 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 5, image 3 de 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 6, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: étape 6, image 2 de 2
    • Now just lift the battery out of place.
14 autres ont terminé cette réparation.
Maxim
Membre depuis le 01/21/15
462 Réputation
1 tutoriel rédigé
Équipe
UWT Liner: Group 6 Membre de l'équipe UWT Liner: Group 6
Community
3 membres
1 tutoriel rédigé
2 commentaires
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Réponse
Great guide. Thanks!
weston.fisher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 16
Total : 7,342
