Aller au contenu principal
Asus VivoBook Q200E-BSI3T08 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 3, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 3, image 2 de 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Battery: étape 4, image 1 de 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 5, image 1 de 3 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 5, image 2 de 3 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 5, image 3 de 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 6, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 6, image 2 de 2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Cooling Fan: étape 7, image 1 de 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 8, image 1 de 1
    • Unplug the power bus for the fan.
  9. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 9, image 1 de 1
    • Lift up and remove the cooling fan from the slot.
  10. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: étape 10, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: étape 10, image 2 de 2
    • Locate wireless card next to battery.
  11. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 11, image 1 de 1
    • Remove the one 4.9mm screw that holds the wireless card in place with a Phillips #00 screwdriver.
  12. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 12, image 1 de 1
    • Unplug the black coaxial cable from the wireless card.
  13. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 13, image 1 de 1
    • Pull the wireless card from connector slot.
  14. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Motherboard: étape 14, image 1 de 1
    • Locate the motherboard under the cooling fan.
  15. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 15, image 1 de 1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  16. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 16, image 1 de 1
    • Remove the PCB board from the motherboard.
  17. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 17, image 1 de 1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  18. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 18, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 18, image 2 de 2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  19. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 19, image 1 de 1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  20. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 20, image 1 de 1
    • Carefully lift the motherboard up out of the slot.
  21. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 21, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: étape 21, image 2 de 2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
Mitchell Jackson
Membre depuis le 05/17/17
742 Réputation
7 tutoriels rédigés
Équipe
IUPUI, Team S4-G4, Wilson Summer 2017 Membre de l'équipe IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 membres
7 tutoriels rédigés
Un commentaire
Very useful tutorial with nice photos indicating even different type of screws n different color..
This was more useful than a YouTube video..
I just replaced my mother board..
Thank you and God bless u for ur effort..
Gs Mobile - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 8
Total : 2,207
