Aller au contenu principal
Asus VivoBook Q302LA-BHI3T09 Fan Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: étape 1, image 1 de 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: étape 1, image 2 de 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: étape 2, image 1 de 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: étape 2, image 2 de 2
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: étape 3, image 1 de 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: étape 3, image 2 de 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: étape 3, image 3 de 3
    • Remove the following screws that mount the fan and heatsink to the motherboard:
    • Three 3.0 mm screws for the fan
    • Four 2.0 mm screws for the heatsink
    • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
Carl Zuehlsdorf
Membre depuis le 02/13/18
116 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 8
Total : 163
