Aller au contenu principal
Asus VivoBook X202E-DB21T Power Port Replacement
Ce dont vous avez besoin
  1. Asus VivoBook X202E-DB21T Power Port Replacement, Battery: étape 1, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement, Battery: étape 1, image 2 de 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Power Port Replacement: étape 2, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 2, image 2 de 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Power Port Replacement: étape 3, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 3, image 2 de 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Power Port Replacement: étape 4, image 1 de 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Power Port Replacement: étape 5, image 1 de 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: étape 6, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: étape 6, image 2 de 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Power Port Replacement: étape 7, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 7, image 2 de 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: étape 8, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: étape 8, image 2 de 2
    • Unscrew the five 5mm screws holding the left board together.
  9. Asus VivoBook X202E-DB21T Power Port Replacement: étape 9, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 9, image 2 de 2
    • Unplug the two connectors on the left board.
  10. Asus VivoBook X202E-DB21T Power Port Replacement: étape 10, image 1 de 3 Asus VivoBook X202E-DB21T Power Port Replacement: étape 10, image 2 de 3 Asus VivoBook X202E-DB21T Power Port Replacement: étape 10, image 3 de 3
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  11. Asus VivoBook X202E-DB21T Power Port Replacement: étape 11, image 1 de 1
    • Remove the six 4mm screws holding the fan and CPU cover.
  12. Asus VivoBook X202E-DB21T Power Port Replacement: étape 12, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 12, image 2 de 2
    • Unplug the fan.
    • Remove the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Power Port Replacement: étape 13, image 1 de 1
    • Unscrew the nine 4mm screws holding the right board together.
  14. Asus VivoBook X202E-DB21T Power Port Replacement: étape 14, image 1 de 1
    • Remove the two remaining connectors on the board.
  15. Asus VivoBook X202E-DB21T Power Port Replacement: étape 15, image 1 de 1
    • Remove the right board.
  16. Asus VivoBook X202E-DB21T Power Port Replacement, Power Port: étape 16, image 1 de 1
    • Locate the power port on the right board near the internet port.
  17. Asus VivoBook X202E-DB21T Power Port Replacement: étape 17, image 1 de 2 Asus VivoBook X202E-DB21T Power Port Replacement: étape 17, image 2 de 2
    • De-solder the pins of the port from the board
    • See this guide on how to use a soldering iron.
    • Remove the port from the board.
2 autres ont terminé cette réparation.
John Thomas
Membre depuis le 01/13/19
756 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 937
