Aller au contenu principal
Asus VivoBook X202E-DB21T Trackpad Replacement
Ce dont vous avez besoin
  1. Asus VivoBook X202E-DB21T Trackpad Replacement, Battery: étape 1, image 1 de 2 Asus VivoBook X202E-DB21T Trackpad Replacement, Battery: étape 1, image 2 de 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 2, image 1 de 2 Asus VivoBook X202E-DB21T Trackpad Replacement: étape 2, image 2 de 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 3, image 1 de 2 Asus VivoBook X202E-DB21T Trackpad Replacement: étape 3, image 2 de 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 4, image 1 de 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 5, image 1 de 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Trackpad Replacement, Trackpad: étape 6, image 1 de 2 Asus VivoBook X202E-DB21T Trackpad Replacement, Trackpad: étape 6, image 2 de 2
    • Remove the ten 4mm screws using a Phillips #00.
  7. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 7, image 1 de 1
    • Carefully remove the metal plate from the laptop.
  8. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 8, image 1 de 1
    • Remove the four 5mm screws from the trackpad using a Phillips #00.
  9. Asus VivoBook X202E-DB21T Trackpad Replacement: étape 9, image 1 de 1
    • Remove the trackpad from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 268
