Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide you will learn how to remove the keyboard and expose the inner components of your Asus Vivobook X540SA-BPD0602V. If you need to make any repairs to your laptop, the first step is to safely take it apart.
  1. Power down the laptop using the device's power button in  top right corner of the keyboard. Ensure that the device's power cord is disconnected.
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Flip the laptop over so the back panel is displayed.
    • Flip the laptop over so the back panel is displayed.
  3. Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Flip the laptop back over and open it, revealing the screen and keyboard.
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Ziyad Alharbi
Membre depuis le 18/10/2017
112 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G111, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 1,418
