Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V's wireless card. Problems with the wireless card will lead to issues connecting to your router and the internet. If being tied down to an ethernet cable is not an option, the wireless card has to be replaced.
  1. Power down the laptop using the device's power button in  top right corner of the keyboard. Ensure that the device's power cord is disconnected.
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Flip the laptop over so the back panel is displayed.
    • Flip the laptop over so the back panel is displayed.
  3. Using a Phillips #0 screwdriver, remove the ten screws from the back panel.
    • Using a Phillips #0 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Flip the laptop back over and open it, revealing the screen and keyboard.
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Use the plastic opening tool to wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • Use the plastic opening tool to wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the hinge.
  6. Observe where the ribbons connect to the motherboard; there are two connections. Each connection has a black clamp. To remove the ribbon, lift up the black clamp and disconnect.
    • Observe where the ribbons connect to the motherboard; there are two connections. Each connection has a black clamp. To remove the ribbon, lift up the black clamp and disconnect.
  7. Very carefully, remove the batteries with the same blue plastic iFixit opening tool used in the first tutorial. Focus your efforts on the combed hinge to the left of the batteries.
    • Very carefully, remove the batteries with the same blue plastic iFixit opening tool used in the first tutorial. Focus your efforts on the combed hinge to the left of the batteries.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not use them.
  8. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  9. The Disk Drive is located within the upper right hand corner of the laptop.
    • The Disk Drive is located within the upper right hand corner of the laptop.
  10. Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  11. Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  12. After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  13. Slide the disc drive to the right, removing it from the laptop case.
    • Slide the disc drive to the right, removing it from the laptop case.
  14. The fan is located near the upper left hand corner of the device, connected to the motherboard and right beneath the wireless card.
    • The fan is located near the upper left hand corner of the device, connected to the motherboard and right beneath the wireless card.
  15. There is a bundle of wires connecting the fan to the motherboard. Disconnect them.
    • There is a bundle of wires connecting the fan to the motherboard. Disconnect them.
  16. Using the J00 screw bit in the iFixit tool kit, remove the three screws securing the fan to the case. One screw connected to the bottom case (4cm), one connected to the motherboard (4cm), and one screw connected to the Wireless Card (5cm).
    • Using the J00 screw bit in the iFixit tool kit, remove the three screws securing the fan to the case. One screw connected to the bottom case (4cm), one connected to the motherboard (4cm), and one screw connected to the Wireless Card (5cm).
  17. Carefully remove the fan from the case using the blue iFixit opening tool.
    • Carefully remove the fan from the case using the blue iFixit opening tool.
  18. The wireless cared is located in the upper left portion of the device case, right above the fan and attached to the motherboard.
    • The wireless cared is located in the upper left portion of the device case, right above the fan and attached to the motherboard.
  19. There are a bundle of wires connecting the wireless card to the motherboard. Disconnect them.
    • There are a bundle of wires connecting the wireless card to the motherboard. Disconnect them.
  20. Carefully slide the wireless card to the right, and remove it from the device.
    • Carefully slide the wireless card to the right, and remove it from the device.
Jessica Browne
Membre depuis le 18/10/2017
741 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G111, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 12
Total : 351
