Aller au contenu principal
Asus VivoTab Note 8 IO Board Replacement
Ce dont vous avez besoin
  1. Asus VivoTab Note 8 IO Board Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 IO Board Replacement: étape 2, image 1 de 2 Asus VivoTab Note 8 IO Board Replacement: étape 2, image 2 de 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 IO Board Replacement: étape 3, image 1 de 1
    • After pulling the panel off, put it to the side.
  4. Asus VivoTab Note 8 IO Board Replacement, IO Board: étape 4, image 1 de 1
    • After removing the back panel, you will see the IO Board under another removable plastic piece.
  5. Asus VivoTab Note 8 IO Board Replacement: étape 5, image 1 de 2 Asus VivoTab Note 8 IO Board Replacement: étape 5, image 2 de 2
    • Unscrew the two screws of the plastic piece, and lift it off.
  6. Asus VivoTab Note 8 IO Board Replacement: étape 6, image 1 de 3 Asus VivoTab Note 8 IO Board Replacement: étape 6, image 2 de 3 Asus VivoTab Note 8 IO Board Replacement: étape 6, image 3 de 3
    • Unscrew the screw holding down the IO Board.
    • Pull out the ribbon (hold the ribbon with one hand and the board with the other, then pull) and remove the IO Board.
Ryan Spencer
Membre depuis le 09/21/18
756 Réputation
6 tutoriels rédigés
Équipe
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 18
Total : 518
