Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus VivoTab Smart Battery Replacement
Ce dont vous avez besoin
    1. Asus VivoTab Smart Battery Replacement, Battery: étape 1, image 1 de 3 Asus VivoTab Smart Battery Replacement, Battery: étape 1, image 2 de 3 Asus VivoTab Smart Battery Replacement, Battery: étape 1, image 3 de 3
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      Demander à FixBot
      Ajouter un commentaire
    2. Asus VivoTab Smart Battery Replacement: étape 2, image 1 de 3 Asus VivoTab Smart Battery Replacement: étape 2, image 2 de 3 Asus VivoTab Smart Battery Replacement: étape 2, image 3 de 3
      Outil utilisé dans cette étape :
      • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
      • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
      Demander à FixBot
    3. Asus VivoTab Smart Battery Replacement: étape 3, image 1 de 3 Asus VivoTab Smart Battery Replacement: étape 3, image 2 de 3 Asus VivoTab Smart Battery Replacement: étape 3, image 3 de 3
      • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
      • Remove the tape covering the areas marked by the black arrows
      • Remove two 3.7 mm Phillips #00 screws
      • Remove eleven 2.7 mm Phillips #00 screws
      Demander à FixBot
    4. Asus VivoTab Smart Battery Replacement: étape 4, image 1 de 2 Asus VivoTab Smart Battery Replacement: étape 4, image 2 de 2
      • Be careful not to damage the speaker wire.
      • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
      • Lift up on the speaker with your fingers to remove it.
      Demander à FixBot
    5. Asus VivoTab Smart Battery Replacement: étape 5, image 1 de 1
      • Gently lift the battery pressure plate off of the motherboard.
      Demander à FixBot
    6. Asus VivoTab Smart Battery Replacement: étape 6, image 1 de 2 Asus VivoTab Smart Battery Replacement: étape 6, image 2 de 2
      • Use tweezers to separate the battery tray from the device
      • Lift the battery tray from the device using your hands.
      Demander à FixBot
    7. Asus VivoTab Smart Battery Replacement: étape 7, image 1 de 1
      • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
      • Detach the battery from the tray by pulling the battery up from the tray with your hands.
      • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
      Demander à FixBot
4 autres ont terminé cette réparation.
Zach Hatten
Membre depuis le 10/06/16
563 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 2-4, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 membres
60 tutoriels rédigés
2 commentaires de tutoriel
Hi
So where is the next step ?!
Albert einstein - Réponse Partager
Hi
Please answer to me. This is so
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 71
Total : 4,084
